Getting more power out of a 55hp Evinrude?
Randal106
Hi, i have a 1979 Evinrude 2clynder 55HP Model Number 55975C. I have replace the entire ignition system and starter. is there anyway i can get more power out of it? what prop would you recommend for pulling kneeboarders, wakeboarders? also, when i hit it full throttle it hessitates then goes, how do i help that? Thanks for any replys
~Randall~
fireman57
Re: Getting more power out of a 55hp Evinrude?
Hesitation when you slam the throttle to WFO is usually caused by junk in a carb. When was the last time you pulled them and gave them a good cleaning? I'm not talking about just spraying carb cleaner in them while you are running. I mean a good soak, blow them out with air, and put a kit in them. Doesn't take very long at all. Another possible cause is a sticking timer base that doesn't let the timing advance with the throttle. That is a pretty good engine and should perform well but don't know what size boat it is on and what your normal load is. If your engine is running good and you need more power buy a bigger engine or put this engine on a smaller boat. There really isn't much you can do to turn a 55 into a 65 or 70hp. If there is then it can't be cost effective to do it.
