ghosting of old vinyl stickers?
tony6813
How do I remove the shadows of old registration numbers? And the weathered windshield rubber at base of window? thanks for any info.
mickyryan
rubber at base of window might be sandwiched between frame and hull , if not its just a snap in need better pics of that to tell for sure as far as numbers go you could wet sand to try to remove them however depending on area involved you could cut through or make it wavy , the oxidation is what did it, try compounding then buffing to see if you can remove them if not you will have to sand and sand ...
chevymaher
Wet sand with 400 1000 1500 3000 paper and then buff. In the pic the upper left is alot worse than you got and it is gone.
daveydoodle
Vinyl at bottom window , I used 1 inch dia. rubber weather stripping after sliced in
