Gimbal bearing install question, need to adjust engine height
makonnen
Hey guys,
Just a quick question ... I'm installing a new gimbal bearing. Just wondering if its common to have to adjust the engine height after installing a new gimbal bearing? I noticed that the gimbal bearing has a crush "ring" that holds it in place. Its possible to be off a hair from when installing the new gimbal brg.
On a side note, I also noticed that the special tool from mercruiser drives the INNER bearing??? I see that a number of companies offer a custom made bearing driver that drives the outer (aluminum) race.
Don S
Re: Gimbal bearing install question, need to adjust engine height
If the alignment was ok with the old bearing, it will be ok with the new bearing. But you will have to align the inner portion of the gimbal bearing to the coupler.
No it doesn't, unless you don't have all the parts to the tool.
http://forums.iboats.com/showthread.php?t=329915&p=3098784&viewfull=1#post3098784
tpenfield
The more common adjustment is the inner race, to align with the coupler. The alignment tool gives you the right amount of leverage to tweak the inner race.
makonnen
KC DREW
Banned
I might be doing my gimbal bearing soon. This was good info. Thanks
achris
More fish than mountain goat
...On a side note, I also noticed that the special tool from mercruiser drives the INNER bearing??? I see that a number of companies offer a custom made bearing driver that drives the outer (aluminum) race.
You shouldn't be driving on the bearing at all... The aluminium 'outer' is the bearing carrier, not the race.
The engine alignment will not have changed, .. the bearing gimbals in the carrier and you need to align it to the engine.
Here's a video that explains it -> http://youtu.be/w118LGsYgY4
makonnen
Yea I'm not going to drive the bearing at all. Just trying to decide if I want to spend the $100 on the proper gimbal bearing driving tools or make my own.
achris
Use a long steel bar and tap around the edges of the carrier... Make sure it goes in evenly...
Chris........
