Recently purchased this as a project boat. It was manufactured in 1998 and has a Mercruiser Alpha1Gen2 3.0. I'm replacing the u-joints, bellows, gimbal bearing & seal and water pump. While pulling the gimbal bearing, I noticed it may have been installed backwards. Notice the notched edge on the upper right side of bearing carrier in picture. I'm not an expert but based on the info for installing a gimbal bearing in the mercruiser manual, this appears to be true. There was quite a bit of grease on the bellows side of the bearing. The boat has been sitting for the last 5 years and was severly neglected by the previous/original owner. When I bought it, I was told nothing had ever been done to the boat except winterizing it every year. I'm guessing the bearing was installed this way at the factory.
Hopefully the picture is big enough to see what I'm talking about.
