Gimbal Bearing Question
1960 Starflite
Just a question. What does the serrated ring on the Bearing/Tolerance ring do? Why is it there? Seams the pressed fit of the bearing OD would force grease around the bearing. Just wondering. Not planning to remove it.
harringtondav
The tolerance ring provides a consistent press fit with mfg. size variations in the transom plate bore and the aluminum carrier diameter. It's similar to a radial crush ring.
1960 Starflite
Thanks, Makes sense. I measured the OD of carrier ring and see .002' variance.
