cjflanagan
- Joined
- Oct 1, 2003
- 168
I want to make sure I have done my Gimbal bearing replacement correctly on my 89 Mercruiser Alpha One Outdrive, this is what I did: I pulled my outdrive; pulled the Gimbal bearing; drove a new replacement bearing home by the race till there was a change in the sound of the hammer (from hollow to solid); made sure that the grease holes lined up, greased the u-joints,splines, and all zert fittings; replaced all the o-rings, replaced the gasket, made sure the shift slide assembly engaged the shift shaft lever, and that the shift shaft coupler engaged the coupler slot; put the drive back onto the Gimbal housing; and torqued all the bolts down to 50 lbs with a torque wrench.<br /><br />Here are the hitches: I was careful to drive the bearing by the race but one stray whack did hit the bearing face putting a dent in it (toward the top).<br /><br />Also, when I put the drive together it didn't just fall together I had to jiggle it around and smack it a few times with a rubber mallet just so that I could get a nut started, which then allowed me to start another, and another etc. till everything finally seated. <br /><br />Normally I would just start it up and see how it worked but I don't want to get water in the engine till things warm up in March. Does it sound like I did things right? Will the dent in the bearing wreck it right away? Should the outdrive have to be squashed together with the Gimbal housing by the nuts (
now that's a quote!), or should it just slide together? Finally, is it possible to set up a remote oil reservoir for my outdrive, I understand that some of the newer boats have this feature. Can I retro fit something? I really like the idea of a sight bottle for keeping tabs on outdrive oil. Any input is appreciated. Thanks in advance -
