I am doing an alignment on my Pre-alfa drive 165 mercruiser. I installed a new gimbal bearing, and I'm trying to do alignment with a driveshaft. What I am finding is that the driveshaft won't go through the gimbal bearing. There is a perfect ring of grease around the shaft where it meets the bearing and there is grease in the splines without any spline wiped clean. Is there more than one ID size for the gimbal bearing?
