I am replacing the gimbal on my 88 Sundancer with a Merc 260 Alpha One. Drive and bell housing are out. The Gimbal bearing looks very clean, except for the grease, and is slightly rough when pressure is applied while turning, so I am replacing it. I have broke several pullers trying to remove the bearing, and have an idea which I would like to pose. I am thinking of getting a very large bolt, and putting it through the bearing, and the seal behind the bearing, through to the inside of the boat. Them put a large washer with the nut. Then from the outside rig up a chain to the head of the bolt, hook the chain to the truck, and pull that bearing and seal out. I just was not sure which side of the transon the seal came out of. It appears it comes out through the drive side of the transom. If it does this seems like it would work. I would have to replace the seal as well.
How does my idea sound?
