Gimbal Bearing Tools
bobterisch
Happy new year everyone,
I would like to make my own gimbal bearing puller and installation tools. I wont have the drive off till spring so does anyone have dimensions for the bearing installation tool and also what is the ID of a BravoIII gimbal bearing?
Thanks!
Bob
Thanks!
Bob
The diameter of the alignment tool is 1.375 which goes inside the bearing
If someone else doesn't provide the outer diameter, I'll make it to the shop and measure one later. If you go and buy the bearing you could measure and make a tool
Bt Doctur
Bt Doctur
To use the plate on a GEN II a additional hole has to be drilled for the oil transfer valve
bspeth
I use an old race on the end of a 2x4 with the 2x4 cut on the end to fit inside the race. Worked fine for installation,just make sure its all the way home so you don't have a problem installing the drive.
imp0ster
This is what I was planning as well. If you have an old one why not beat on it to drive the new one in!?
