gimbal bearing
leeann4
long time reader, first post<br />it was sunday, getting ready to install out drive<br />(alpha 260 merc)stuck hand in bellows to inspect gimbal bearing. IT DID NOT TURN. it was brand new last year. as i think back there was some oil in bellows when i took it off for winter. freind said it was probaly lube from ujoints from getting warm. now i dont no what to think where should i start other than replacing gimbal bearing. the greese in bellows did not seem to have water in it. help
vipzach
Re: gimbal bearing
Welcome to iboats! Are you sure that you were trying to turn the bearing? Oil being in the bearing won't make it lock up, water definately could though. I would pull the bearing out and see why it isn't turning.
Laddies
Banned
Re: gimbal bearing
When installing the gimbal were you careful to only pound on the outside of the brg. if you pounded on the inside you ruined the brg. installing it
