timg19
- Joined
- Sep 1, 2011
- 66
I just pulled my boat out of storage and I'm performing some regular maintenance on it. I read in the owners manual that the gimbal bell-housing bolt torque should be checked every year (should be 50 - 55lbs). When I checked, one was at 30lbs and the other was 25lbs (my wrench is good, I checked the torque on other bolts).
I've also read that you shouldn't re-torque these bolts after the gimbal bearing is in because it can cause the bearing to snap. Should I leave these boats the way they are, or tighten them up to 50lbs?
History of the boat:
- I remember the boat shop saying they re-torqued these nuts two years ago when I had it in for new bellows. They have not been touched since then. Gimbal bearing currently is tight and looks / sounds good. This is a Alpha 1 Gen 2 outdrive.
