Folks, I posed this question over in the restoration section but thought it may be better to follow through here. I have a gimbal housing that clearly has come out of a 4 or 6 cylinder. This is an MC1. The bottom ports where housing mates to y-pipe are blocked off. I see this is normal for non-V8. The casting looks like it is exactly the same as V8. I assume there is a modification that can be done to have bottom exhaust ports go through.
Question 1: Has anyone made this modification?
Question 2: If not, would anyone have pictures they could share of a V8 housing? An 898 or 228 sterndrive is probably the correct housing.
I will post details of this modification if someone could help me out to understand what the end result looks like.
thank you in advance
