Gimbal housing seal gone bad
89Sea
Hi,
I have a 89 Seaswirl with a 5.8 OMC cobra. I am in the process of repairing the lower shift cable and want to replace the gimbal housing seal (not the bearing seal). Does anyone know where I could get this part online?
The problem I am having is water leaking into the bilge area. I suspect the gimbal housing seal is leaking because I have replaced the U-joint bellows and other seals. I have the outdrive off and was wondering how would I go about repairing the gimbal housing seal. Do I have to pull the motor?
Thanks
proshadetree
Re: Gimbal housing seal gone bad
The seal between the housing and the transom, yep engine has to come out.I got a transom kit off of ebay. Check that wood while it is out mine was rotten as crud
Ayuh,... That's the most common reason for that gasket to Fail...
