76SeaRay
- Joined
- Aug 24, 2017
- 1,071
This is an Alpha One Gen One. At the very top of the housing, there are two bolts that look in great shape (almost new looking). Next going down the drive are the two long studs that look in good shape with some corrosion on the tips of them on the drive side of the gimbal housing. The ends that go through the transom and inner transom plate seem to just have very light surface corrosion. Continuing top to bottom, the next two bolts with the square washers are severely corroded away to about half their thickness (surprised the came out without breaking). Finally, at the bottom are the two "zinc" bolts and they appear in good shape as well.
My question is, should I pull the studs out and replace them since the two bolts right below are so corroded? I don't know why the two bolts with the square washers are so corroded compared to the others. I can only guess that the top and bottom bolts were replaced at some point in time but not the corroded bolts. I am just concerned with the studs and whether they are heavily corroded inside the threaded hole since they appear to be originals and should be changed now. I haven't attempted to take them out (let sleeping dogs lie???)...yet....
