Gimbal Housing water inlet corrosion
beruken
Any chance of saving this housing with jb-weld or an insert? I'd be wary of any product breaking loose and blocking my inlet or breaking the water pump.
Ken
achris
More fish than mountain goat
That actually look pretty normal. Anything wrong?
beruken
Even around the seal area? Seems to be missing some metal. I did have salt water leaking as seen from the inlet into my bell housing which corroded my u-joints and gimbal bearing. Not sure if the seal fell off during last install.
achris
If you're concerned about it, use some Devcon to build it back up.
