gibbywmu2000
- Joined
- Apr 20, 2008
- 116
Hi Everyone,
After hours of researching online, it looks like my Gimbal Ring (not sure about bearings, I'm not getting any noise) needs replacing. I have quite a bit of slop in my drive when I move it from side to side. From a video I watched from JR Marine, mine definitely needs some work. I'd love to do this myself, but this looks like quite a task. Sounds like that outdrive is pretty heavy, and I don't have a special jack or anything to be able to get it off (nor do I have the time). I'm assuming its those bushings that need replacing that cause the side to side slop?
Here's my question. Assuming I take it to my "honest" local marina, what is an average cost for a job like this? Lets say if they inspect the bearing and that seems ok? I heard the steering nut could be lose also which would create the same symptoms? If its a huge $$$ job, I'd like to put this off until next year if at all possible, but I still want to be able to drive the boat as well............just not sure if that is possible and I'd cause more damage with the slop it has?
Any suggestions would be appreciated
