Gimble assy. rebuild and transom repair
jeffmc3814
I am working on a 26? Wellcraft. I wanted to ask if anyone knows what torque is required when installing my transom plate. I have rebuilt the transom assembly and made some minor repairs to the fiberglass surrounding the transom opening. Now I am ready to re install the gamble housing and transom plate and could not find any info on how much torque is required to prevent any leaking. I have new gaskets as well. Oh should I use caulk in addition to the merc transom seal? I was thinking it would hurt to run a bead of caulk ? between the factory gasket and the transom opening on my boat. Any help would be appreciated
Jeff
oops!
Re: Gimble assy. rebuild and transom repair
hi jeff.....welcome to i boats......
that question is more for the mechs on the i/o forum....as the touque specs are their territory......as far as the sealant.....its not nessary, but i have seen it used.....sikkaflex or a 3m 4200.
as long as the transom is flat.....i think there is as much as 1/8th tollreance between any two points from the inner wall and the outer wall....the gaskets will take this up...
if bond-o peeks down here he can answer......
btw....if you pm a mech on the forum...just post the link to the thread in the pm......that way they can answer in open forum.
cheers
oops
jeffmc3814
Thank you for directing me to the correct form.
