Glasply 470 steering ram
aarons 470
By chance does anyone know what thread pattern and size this fitting is? It’s Close to 3/8ths size wise, but hole is just a tad smaller. So it probably isn’t npt.
Hole is just to the right of the smaller hydraulic hose connection. This hole is for a hose 3/8ths run from the power steering cooler.
Bt Doctur
Where is the end that was on the hose. This is a low pressure line . Any hose rated for oil will work.
Fitting is an inverted flare
aarons 470
Ordered that flared fitting assembly from the link you provided. Fit right up.
Thanks again.
