Glass Fuel Bowl and Filter questions in a 59 Lark
clarky711
Greetings,
My 59 Lark is having some problems and I may have linked to a fuel one (at least it's a start). Is there supposed to be a rubber gasket or O ring that seats the glass bowl tight? I'm getting fuel squirting out when I prime the engine and when it attempts to run.
I did have the bowl loosen up and fall out once when running so it's possible that the O ring could have fallen out. The little filter in the bowl is starting to crack, does anyone know where I can get a replacement for that?
Also, as I asked in another post, what is the safest way to check for spark without and special testers and without getting zapped?
Thanks again for your help in advance.
Mike
CATransplant
Re: Glass Fuel Bowl and Filter questions in a 59 Lark
Yes, there's a gasket for that fuel bowl. Your local dealer should be able to get one for you. Preserve the bowl, since they're hard to come by.
As for the spark test, I call my idiot brother in law to come over and stick his pinky finger into the spark plug boot while I crank the engine. I can tell how good the spark is by how loudly he yells. :D
Seriously, an adjustable spark tester is cheap and should be in your toolbox.
Chinewalker
You can lay the plugs against the block and spin it over. Spark should be bright blue/white with a sharp snap...
The filter and gasket are dealer items and should be readily available.
- Scott
clarky711
The sparks felt like it was a sharp snap alright!:eek:
anyway, does anyone know of the part # or the dimensions of the glass bowl seal? I'm guessing it's just an o-ring right?
thanks again for the help...
Mike
rjezuit
I have a 1956 15 Hp, don't know for sure if it is the same, but the bowl is P/N 303121(item # 62 on my list) and the gasket is 303122(item # 66). The gasket is 7/8 ID X 1 1/8 OD X 1/16" thick(flat) I am asuming BUNA-N material.Rick
F_R
Nope, the 35 in question is
302675 gasket
305185 "tea bag" filter
303967 glass bowl
377600 thumb nut and yoke retainer.
clarky711
thanks FR, just ordered the part from my local dealer!
MC
