F14CRAZY
Ensign
- Joined
- Aug 12, 2008
- 945
I'm helping my best buddy with his Wellcraft Nova 210XL. In the process of swapping his 302 for the proper 351 he found the engine mount lumber to be wet. I've got them cut out and I'm grinding the rest right now (actually in my tyvek suit at the moment). The transom, bulkhead ahead of the mounts, deck and stringers check out to be solid.
It's obvious someone replaced these before and just didnt seal the lag bolt holes properly into the mounts. Each they're two 2x6s attached together about 37 inches long. I have some dry PT 2x6s with me, some 18 oz roving as I used in my Capri restoration, and a gallon of premium poly resin from US Composites that I used in fixing some gelcoat scrapes on his parents Capri.
Being that I've only laid up glass with epoxy, do I need to use a layer of CSM or something over the wood first before the roving? Was there any other thing thats different between laying with poly versus epoxy? thanks guys
