First off, You REALLY should keep your posts ALL IN ONE THREAD. It makes is a LOT easier for everyone to follow along with what you are doing. But this is a generic topic so it is somewhat off topic for your rebuild. Glassing in High Humidity should not be an issue. What WILL be an issue is the temp. The resin will SET rather quickly unless you cut back on the MEKP a little but NOT to much or you will weaken the mix. This has been discussed quite a bit on the forum an a quick search should have yielded quite a few results. Check out all the links below this thread!!!!!
