Re: Glastron MX 175...good first boat????
Ahhh...nothing like that new boat smell. Not having to worry about rotting structure, poor past owner engine maintenance, having a warranty. I myself have never owned a new boat, all my boats have been older than me, and I have had to do a lot of work on them. I enjoy that, I have no family, so thats fine with me. It seems to me that you want to just avoid all the nonsense and just get into a boat that you and your family can use and be happy with. I think the boat you are proposing will do fine for cruising, you don't need to break any speed records, you are just out there to enjoy the water. I think the boat will do okay for fishing as long as you understand that there will be compromises. If you are a casual fisherman, it should be fine. As for water skiing, you may have less than a satisfying experience with the limited power unless you and you family members are exceptional skiers who have the skill to ski behind a low powered boat. Now, I see people skiing all the time on low powered boats on my lake. You shouldn't have much of a problem pulling water toys, although the speed won't be blinding.<br /><br /> If your budget can allow it, I recommend trying to go up to the next power package. You will be happier, the boat will hold more value, and you will save money in the long run because a small motor that is worked to death will need more maintenance than a larger motor that is not working as hard. If you absolutely cannot afford anything but the base power package, then just buy the boat. Unless you know the person who owned the boat and know for sure how it was cared for, there is alway risk with buying a used boat, and with risk comes cost. In your situation with having a family and considering a base level boat, I can only assume you are not rolling in money. Having to rebuild an engine or do a structural repair can end you up with having a useless boat in the backyard for years, whereas just making that small monthly payment and going out with the family is so much better. Good luck with it however you go.
