Re: GlenL aqua cat...
Originally posted by sundog:<br /> ..how fast will that girl go?<br /><br />Im going to do it anyway.
That's the spirit! Even if ya can't work on it as much as ya want, it'd be a great project to work on for a hour or two after the kids & the Mrs. go to bed, or something to do instead of watching TV on the weekends. I've had some project or another, either a boat, or a hot rod, a dog house,,, something going on all my life to keep occupied and out from in front of the TV. <br /><br />Its amazing how much kids like to help, and how much they learn from helping you too.... Mine sure did when they were that young. <br /><br />Anyway:<br />Yeah, its TIGed. I did a 12' 'D' hydro back in the 90's with a MIG wire feed machine. It can be done with one, but not by me. The welds were pretty ugly, and I don't have a lot of confidence in them.<br /><br />For this project, I took the plunge and got a Miller Econo-TIG and taught myself (with a little help from my friends--- who actually know how to use one) how to use it. Its great. For this boat, I've used about 15 lpounds of Aluminum welding rods, and 12 of the big (125 and 155cuft)tanks of Argon. I think I'm up to about 7,000 rivets too. <br /><br />Its not quite done. I hope to start my 'Sea Trials' in about 2 weeks.<br /><br />Its got a 2.4 Merc. V-6 150 hp. The 2.4s are like Chevy 350 V-8s--- there's no end to all the hot-rodding you can do with them.<br /><br />Mine is a 150hp. But the same basic engine with different carbs, different heads, etc, is what Mercury gets their 150, 175, 200, and 225 engines from.<br /><br />This hull weighs less than 600 pounds, closer to 500, its airfoil sides should generate about 300 pounds or so of lift to get it up out of the water- cutting drag and resistance. I expect nothing less than 80 from it right off the bat.<br /><br />This winter I'll be sending out the heads for machining work, playing around with reeds, props, carbs. etc. What I'm hoping for is to get it over a hundred mph while keeping the RPM under 7,000 with this engine. And believe it or not, still be stable and safe to drive.<br /><br />Ed.
