GLM casting flash
roach502
Just got a set of new iron manifolds for the 502 today,they look pretty straight but notice quite a bit of casting flash around the mouth of ports.Think i could clean them up with the die cast grinder?I port match the heads and intake, and the machine shop said i did a good job for a firsttime job on a v8 other than porting bikes.THANKS
chiefalen
Re: GLM casting flash
Hope so been hearing horror stories about glm.
Make sure the mating surfaces are true.
Ayuh,...
And a flat File accross the riser flange, to check for Flatnest....
