Gluvit Paint Question
Johnshan1
Is Gluvit paint suitable to be used as a primer? I have an epoxy finish that I need to paint, would this be okay to use as a base/primer coat?<br /><br />Thank you!<br />-John
outonbizniz2
Re: Gluvit Paint Question
I used gluvit in this fashion to and seal up crazing. I wouldn't recommend it. I went on really thick and caused brushstrokes htat had to be sanded out. Once cured it doesn't sand easily and really gums up sandpaper fast.
D
DJ
Guest
Johnshan1,<br /><br />Not as a primer. Gluvit is designed to be used to repair hulls, not coat them.
heatherjoy
We thank you for your replys! The next question is, would Z-Spar be a good paint to use on the interior? Bare epoxy of course. I am not sure if they make a primer or not.<br /><br />Second option is to use a Pettit Primer and then the Pettit paint over it.<br /><br />Our goal is to find a paint that hides minor surface imperfections while providing a decent finish.<br /><br />Thanks!<br /><br />-Heather/John
