Hey Everyone,
I am new to the site and just acquired a '66 Valco 14' Aluminum Boat from grandpa and I am currently getting ready to make it a project. I already have most of the inside cleaned out and down to metal and have a qt of Gluvit ready to go. I am wanting to paint it and from reading forums on here I have learned that I need Self Etching Primer for the Aluminum. Now my questions are:
Should I Self Etch Primer the inside First, then Gluvit the Seams and Rivets, and then use a epoxy primer over JUST the gluvit?
OR
Gluvit the Seams and Rivets First, but then what primer do I use? I am not wanting to Coat the entire bottom, just the seams and rivets. Can I use the Self Etching on the Gluvit? Or am I gonna have to Self Etch Primer the Aluminum, then Use Epoxy Primer on the Gluvit Areas, and paint over that with marine paint?
Any Info would be greatly appreciated. I have read about using gluvit, then using the appropriate primer over that and I have read about just using Self Etching on bare Aluminum, but what if you are in the position where you will be painting over both?? Thanks Everyone. Like I said, I am a newb to boats.
OR
