shadowrider
- Joined
- Feb 19, 2009
- 195
I am replacing the floor in my 71' 16' Starcraft SS. This was going to be a quick floor job, but is escalating into more work as I read more, and see others boats nicely restored. After reading several posts about gluvit, I am apprensive about using it. The boat has no leaks. My concern is that it will do no good on rivets above stringers. Topcoating a double layer of aluminum will not seal a leak under the stringer, so I thought I would save gluvit for a useful purpose. Also it will run off of any seam it is applied to, unless the seam is level. I can not roll the boat to get it level, too heavy with motor attached. I am trying to get it back on the water asap as salmon season is in full swing. I will apply it to all rivets below water line that are through single thickness inside hull.
I was thinking about using gluvit on the new ab marine ply floor instead of wasting it on rivet seams at an angle where it will run off. I have a quart of it, originally thinking I would just do rivets, it is supposed to cover 25-30 square feet, that is only 5'x5', which is about 1/3 of the floor, so, I am wondering if it will cover more when applied to plywood ? Seems like it would be easier and faster than going the poly resin/glass route. Is there a simple method of keeping gluvit from running away from desired area ?
Has any one used it on plywood , if so did it go furter than 25-30 sqft ? Thanks for reading this long winded post, and any replys.
