GM 350 compression
diesel1960
Have inboard GM 350 (Volvo Penta AQ290A)
Did run compression test on this engine ,not sure if results are satisfied :
cyl #1-150psi
#2-150
#3-150
#4-140
#5-130
#6-150
#7-148
#8-135
repeated test twice to confirm,need to run one or two seasons of this engine before rebuild.
achris
More fish than mountain goat
Re: GM 350 compression
Nothing wrong with those numbers... High enough to be happy, and only 20psi variation, within spec.
beermak
wish to read those numbers outta my engine!
i have the same engine. Take good care, i dont believe you should worry on a overhaul right now.
