Sea Ray 220cc 1978.previously had pre-alpha outdrive MC-1 with gm305 carburated,now it has SE106 outdrive with gm350 with the fast burn heads(64cc 200-210psi) NEVER HAS WORKED PROPERLY.A week ago when idling at the dock i noticed drops of water exiting the starboard cylinders.Since the block ,the risers,the risers' gaskets , the intake manifold and the ex- manifolds were new i isolated the exhaust manifolds from the raw water cooling system and i drove the water exits directly to the sea with long hoses instead of the risers.I worked the engine for about 15 secs and at that time the plugs were dry.I repeated the test and i'm sure that the exaust fumes do not permit the water to exit through the pipe.I think about diving and taking out the exhaust bellows to reduce exhaust pressure or go to a through transom exhaust to find out what is going on.Have you ever met this problem? (I also have water in oil but i bellieve this is through the rings).The old intake manifold was rusty at the intake ports and the base of the Thousing very black.(I checked fuel and it is clean).
Thanks in advance
Thanks in advance
