Going from 25 hp to 35 hp
jitterbug127
I finally heard back from Smoker Craft. My flat bottom is rated for up to a 35 HP outboard. I am going to look to buy or trade my 25 hp for a 35. I can get up on plane well with 2 guys in the boat, but I am struggling to get on plane with 3. I assume a 35 hp outboard will help with this. Ill look at getting one of those whale tail things if I'm still struggling to plane after the increase of 10 hp.
jitterbug127
Will do! Suggestion on what to check? I've messed with the tilt a bunch on my boat and motor. It has 5 different spots (i think maybe 4). I have the best luck with the motor on the second to lowest setting (by lowest I'm saying if the prop is all the way down this is next one up). The boat and motor will do about 27 mph with 2 guys in it planning well. We added a third guy fishing the other day. It didn't want to get up on plane.
airshot
Where did the third guy sit ? Balancing weight on a small boat is very critical. So is prop selection...a change to a lesser pitch might be needed when that third person is added. On my 14' old tinnie, I carried two props so I had a spare, but one was two inches less in pitch for when I added that third person. Experiment so you know....When I switched props, I also knew which trim settings I needed to change.
jitterbug127
Right in the middle of the whole boat. I was thinking prop might be a good idea to check too!
jitterbug127
My jon boat is a 16x54 smoker craft big jon. Its heavy before I even get anyone in the water
Boat 340 lbs
Outboard 115
Battery 40
Powerdrive 45
Plywood floors 100 +/- (Im going to 1/2 inch eventually)
Anchor 15
Guy 1 200
Guy 210
guy 3 150
Gear and other crap 50-100 lbs
Were probably around 1300 lbs more or less. I have no idea if thats a lot of weight for a 25 hp outboard or not.
saltchuckmatt
HP is HP....often times when your using the same block size kick out of the hole and getting on a plane are better. My 2 cents.
cyclops222
How wide is the hull at the widest place ? At the straight across bow ? How many gallons of gasoline tank ? Gallons of bait tank ? Type and weight of seating ? Or only aluminum bench seats ?
jitterbug127
6 gallon fuel tank, no bait tank, ive got 3 of those foldable seats. 2 on pedestals and one on a homemade bench seat. One or two aluminum bench seats have been eliminated.
airshot
Boat 340 lbs
Outboard 115
Battery 40
Powerdrive 45
Anchor 15
Guy 1 200
Guy 210
guy 3 150
Yep....your pushing some weight there, with the right prop it should plane but gonna slow it down. Another 10 to won't make a big difference in performance, but might be enough to plane if you have the right prop.
cyclops222
When you remove 1 or 2 bench seats. You make the boat a submarine. If it takes on too much water, too fast.
