going from 3.8 to 5.7?
greentahoe
While my boat is out of commission due to a destroyed upper gears on my stringer outdrive, now might be a good time to think about changing from my 3.8 to a bigger engine, possibly a 5.7. Does anybody have the dimensions of an OMC 5.7 engine/stringer system from the inside of the transom forward, the height from oil pan to flame arrestor, and the width from the outside of each exhaust manifold?
I now have a 4bbl Rochester carb on the 3.8 which is supposed to give me a rated 185 hp. On the 5.7 would I really need a 4bbl carb, or would a 2bbl work well and give better fuel economy? I really don't need more power than I currently have. The main reason for changing engines would be that it is cheaper and easier to find parts for the 5.7 than it is for the 3.8.
Don S
Re: going from 3.8 to 5.7?
You will need to change your gear ratio in the drive for the V8.
IF,....... You were to go thru the Labor of changing to a 350,.............
It would be Easier to just JUNK the Stringer Drive,+ Go with a Newer, Better Drive as well as the Motor..........
Soooo,.............
Can it be Done,.........??.....
Ayuh,........ But, WHY,.??........
If you want Cheaper,+ Easier,..............
Loose the Stringer Drive............................
DHPMARINE
There are a lot of newer better boats out there.
DHP
whywhyzed
Banned
never seen a marine 350 w/ a 2 bbl... I doubt you'd save any fuel.
except for rear riser manifolds, 3.8's are a dime a dozen. There's a recently rebuilt 229 in my local paper tonight, complete, from an 83 Monte Carlo for 75 bones...
Don S
EVERY 350 put out by Mercruiser and Volvo since 98 (I think) has been 2 bbl. If you want something bigger, you go EFI.
