starcraft guy
- Joined
- Jun 11, 2002
- 73
I am going to mount a outboard on a 21 ft' starcraft, Inboard outboard is gone, After i cover hole and brace transom from the inside ,<br />Build a bracket to mount outboard on, There won't be enough clearance to tip motor up,I want to keep motor as close to transom as possiable to lesson stress, I'm thinking of building the <br />bracket so that the motor mount half will slide<br />straight up and down , So that motor will lift out<br />of water,I a'm thinking of using air shocks with <br />a long travel to raise motor straight up,I will also have a locking device to keep motor in place<br />when down,A small compressor and air tank should<br />lift motor,I think. Now i'm looking for ideas that<br />anyone may have to assist in this undertaking<br /> Thanks River Run
