I have an aluminum boat, approx 26 by 9 feet with a vee of about 20 degrees and 7500 pounds.
Engine's a Volvo AD41P diesel (200 hp) and the regular leg is a DP-E (290) with 1,95:1. Normally I cruise at 24-25 knots at 3200 rpm with a 12 psi boost with A7 props. Top is 32 knots.
Now I'm swapping for a SP outdrive for the winter (due to ice) with the correct 1,61:1 gearing. Prop calculators state that I need about prop that's about 15,5-16 x 19 to keep my speed. I tried a 14,3 x 19 Solas and it was useless (17 knots at 3500 rpm) , now I have a Volvo 16 x 19 which is better but still a long ways from the DP. Now I'm doing 21 knots at 3300 rpm so 16 x 19 seems a tad small still.
From trying out several different props on my DP it seems that my boat likes big props so I guess that might also be applicable to the SP drive.
I've found an adapter that lets me use flo torq hubbed props on a Volvo leg. Now I'd like opinions on what prop to get.
I've looked at Suzuki and they turn 16 inch dia props on their larger outboards. So maybe a 16 x 20 or perhaps even a 21 stainless (I need stainless because of the ice). But the Mercury has loads of props but I know nothing about them.
Suggestions?
Suggestions?
