I have a 1989 Johnson 150hp VRO on a 21' walk-around which needs a new fuel pump. I'm thinking this might be a good time to go to premix. My replacement VRO pump is #5007420 and the no oil premix pump is part # 5007422. I expect that the premix replacement pump will be an easy install using the same mounts, but the bad news is that the premix pump is still very very expensive compared to other gas-only pumps. I don't suppose that Johnson has mounts on this engine for the cheaper pumps. If not, would it be possible for me to adapt one to fit, by connecting a tube to the vacuum pulse outlet and connecting up the 2 gas lines? Will this vacuum line be enough to run a standard or aftermarket pump? If so, do you have a Sierra or other fuel pump to suggest. I should be able to fabricate a mount for it . Or would you just advise me to bite the bullet and order the #5007422 premix pump... I've seen it available for $225 plus shipping.
