going to look at a 1999 248CCR
JeepXJer
Hey all. I was going to drive tomorrow to go check out this boat.
1999 Crownline 248CCR
Are there any particular questions i should ask this seller? is $22,000 fair for this boat. It has 460 hours on the 7.4L 454 V8. It has the Bravo III drive.
what do you think about it guys and gals?
-Brendan
burp
Re: going to look at a 1999 248CCR
Brendan,
Your link didn't work for me so the info on the boat could not be viewed. As far as a 1999 Crownline 248CCR, it should be a decent boat if the previous owner took care of it. I know of no common or known problems with the boat itself. Crownline started using XL plywood in 1998 which comes with a lifetime warranty against rot. Some Bravo 3 outdrives had corrosion issues with the bearing carrier assembly back then. Merc addressed the problem and the newer carrier assemblies have a green color.
One thing that would be worthwhile to check on the outdrive is the play in the outdrive/steering. If the steering arm/gimbal ring bolt torque was not checked when serviced, the gimbal ring may be worn and need to be replaced. Grab the outdrive and try to move it side to side. If the outdrive moves several inches side to side and the steering wheel doesn't move, I'd have it evaluated by a mechanic or negotiate on the price.
JeepXJer
well we went out and bought it, so thats why the link doesnt work lol
but everything looked good. they said that they will do a full 80 point inspection, fix some small things for us, and fully detail it before we pick it up in two weeks
