Re: going to take the head off the 75 force and install new head kit
Do you mean taking them off, or putting them back on. What is your spec? I redid a 90 hp force, and don't recall having any trouble like that, but the torque spec was within reason.
Make sure you are reading the manual right because mine in listed in inch lbs not foot lbs for the head bolts.To convert from in-lbf to ft-lbf multiply by: 0.083333309<br />Conversion result: 120 in-lbf equals 9.999997 ft-lbf.<br /><br />I went to ask.com to get this conversion hope it helps, sounds funny though
Snapping bolts off? Naaah...just follow the "torque and turn" method precisely.Make sure the bolts are CLEAN(ie;wire brush them)and lube the treads AND bottom of bolt heads with your 2 cycle oil. Go with an inch pound torque wrench though.A foot pound wrench is too iffy on this low rating. Good luck
