gonna wreck chine walking bad
Status
Not open for further replies.
dannyman3
i have a 19ft stelth bass boat with a efi 150 hp 4 blade 23 pitch prob this motor has a hole in the foot for the speedometer and i haft to adjust this so hi it dont work i have a jackplate and a whaletail when i set it to where the speedometer works it will get up to 55 mph and start china walking bad you can adjust the motor up to where its not as bad bad the oemter dont work and turn hard it will spin the prop do i have a prob how do you set the motor some one told me level the boat the take the level from the pad to whaletail im lost thats for sure dont want to get killed so hope someone helps me
1946Zephyr
Re: gonna reck china walking bad
Well, someone who is going 55mph on the water and posting like this kinda scares me.....really.:eek::eek:
bktheking
I started thinking of the opening tune to the show "Doctor Who" when I read this post????
5150abf
To clarify, it is chine walking and that is bad, lots of bad things can happen when your boat is doing that, I would slow down when it starts.
The cavitation plate shoudl be 1''-2'' below the level of the hull.
Look into getting a GPS, the pitot tube speedos are notoriously wrong so you could be going 55 or 45 or 65.
Faztbullet
Well first things first: (A) Why do you have a whale tale as you should not need it?(B) What brand prop?(C) What size setback jackplate(4",6",8"10")?(D) What is primary use of boat?(fishing,sking,both)
dannyman3
the whale tale was on there when i bought it i have removed it and the prop is a power tech i was using a gps the boat level and motor leavel the cavitation plate was 3 inches above the hull i have droped it level gonna try that and for the one who write bout the way i write you go below im not a poet and dont want to be have a nice day
bktheking
Not really about being a poet or not, more about understanding the post. Clearly wasn't an attack againt you but when you are left wondering what "gonna reck china walking bad" means , I thought the post was from a spam bot , I was expecting to read the topic and then read about the next big stock or viagra.
dannyman3
my bad the prob i was having was when i lower the motor it would get worse even at lower speed and would all but have the prob out the water before could get close to 55 mph there is lot motor left just i know the cavitation plat got to be close to the water i just dint know how raising the motor it would drive better really thats all i need to know my jackplate is 6 inch one pice with adjuster in the middle i just got the boat and tring to set it up for bass turneys i took it to boat shop today they removed the whale tail and lowered the motor 3 inches hope its better thanks to all for help
emdsapmgr
It is normal to setup a boat so that when you are on plane and the engine is trimmed out, the water running from under the boat transom passes just under the engine's antiventilation plate just above the prop. If the engine is mounted lower than that setting, it will cause exess drag and water spray at the back of the boat-resulting in slower speeds and poor fuel economy. The performance guys that have a high rake prop tend to mount the engine slightly higher to decrease drag and increase speed.
Status
