Good & bad about baja 22' caliber tc cruiser
jdavisjp
I am thinking about buying a 1994 22 Caliber tc cruiser w/454 eng. It has 250 hrs and looks to be in good sape. Does anyone know if there is anything bad about these boats that I need to look for? Are they usually a pretty good boat? What do they usually go for.
Thanks for any help you can give
tashasdaddy
Re: Good & bad about baja 22' caliber tc cruiser
i don't know the boat, but-----Buying a boat
1st you need to decide what you want to use it for, fishing, cruising, or water sports.
2nd how many people adults, children you want on board of the average outing.
3rd outboard, inboard-outboard, or inboard power plant.
4th Budget, what you want to pay, and what you are willing to pay, when you find
Exactly what you want.
You can hire a marine surveyor, to inspect the boat, or you can do it yourself.
You are mainly looking for soft spots in the deck, transom, cracks, all signs of a rotten, under frame.
The motor should be clean, no spots where the paint is discolored, or pealing from heat, having run hot. Compression should be atleast 100psi, and within 10% of each other,
Spark on all cylinders, good pee stream, check lower unit for water in oil.
The overall condition of the boat will tell you a lot, as to how it has been maintained.
A 30 year old boat motor combo, may be in better condition, than a 3 year old.
