Good Compression - Low Power???
rg2
I recently purchased a 1999 Merc 9.9 2S. First time out it seemed like the carb need adjustment - it would run fine at wot but when you slowed to just before idle it would idle rough and eventually stall. I took the carb apart and cleaned it out then I placed the motor in a barrel and made adjustments to the low speed idle screw. Seemed to run fine in barrel - no stalling.
Took it out tonight and it ran like crap at first - it didn't seem to have as much power as first time out and actually would lose power while at full throttle. Played with idle speed adjustment but only made slight difference. After about 15 minutes of run time it began to run fine again and seemed to do so until it got to dark and had to take it out (maybe 15-20 minutes).
I had previously checked compression several times consistently 105psi in each cyllinder cold and 110 psi warm. Spark appears to be ok as well. Temp of water out of tell-tale stream is 110-115 degrees.
Is it possible that a seal or gasket may be a little loose or worn and self seals once the engine block warms and expands? Can you think of anything else that it may be?
Thanks in advance guys.
Mi duckdown
Re: Good Compression - Low Power???
The only way you can adjust the low speed idle is. turn low speed in gently untill it stops. back it out 1 and 1half turns. that is the starting point.
Now you need to get the motor running and warmed up.
tie the boat to a dock for and aft, so it won't go anywhere. and put the motor into gear. then turn the idle screw in untill it stumbles, then back it out untill it stumbles somewhere in between is the setting. richer is better. You reaaly can't set in a tank or on a hose.
Plus the low speed setting has nothing to do with WOT
rg2
I guess I wasn't too clear. I made the adjustments to the low idle speed screw prior to taking the boat out on the water. The adjustments I made on the water were with the idle/primer knob on the front of the motor that allows you to adjust idle speed from slow to fast. I believe the low idle speed is ok I just am not sure why it ran so rough at first then seemed to run fine later? If one of the cylinders were not firing for some reason (bad plug) wouldn't the motor vibrate quite a bit besides losing power?
rg2
Anyone else have some advice? Where's Faztbullet when you need him?:)
