Good compression?
ryanr623
I just bought a boat (see sig). The dealership always checks them out before selling them. The engine is a 4.3 mercruiser. Compression seems good an even on all cylinders, however I've only ever done compression readings on two strokes. I know that 130-150 is good for 2-strokes.... is it the same for 4 strokes? Here are the compression readings:
1: 140 psi
3: 140 psi
5: 140 psi
2: 145 psi
4: 145 psi
6: 140 psi
Don S
Re: Good compression?
Nothing wrong with that compression.
Thanks. I'm assuming 130-150 holds true for four strokes as well then?
Ayuh,... Pretty much Any gasoline powered motor runs above 100psi, 'n below 200psi...
ryanr623
OK, i mis-spoke, is 130-150 optimum
Edit: nevermind, just saw the link, thanks!
HT32BSX115
1: 140 psi
3: 140 psi
5: 140 psi
2: 145 psi
4: 145 psi
6: 140 psi
Good compression......
However, if you live where you experience freezing temps, I would insist on a cooling system pressure check!!
