Re: Good prop for 1991 2050 Bayliner 5.0
None of the recommendations given so far make any sense whatsoever....I'm guessing they must have misread your question....so far its just seems like random numbers are being thrown about, and the recommendations are the exact opposite of what you need to do.
Currently you're spinning more than 5,000 rpms with a 21 pitch prop. This is too fast. You slow a motor down by ADDING pitch, not subtracting pitch. So I have no idea where these recommendations for 15, 13, and 17 pitch props are coming from, and they are flat-out wrong....if you put any one of those props on your motor and your tach will exceed 6,000 and you'll likely cause damage to motor and/or outdrive. Of course your holeshot will be spectacular....
You probably need a 23. But this assumes your data is correct....and I somehow doubt it. I find it hard to believe you can exceed 5,000 rpm, but are still disappointed with your holeshot. Your holeshot won't get any better than it is now while you are seemingly underpropped....
What is your outdrive gear ratio? And what is your top speed when you're running 5,000 rpms? You reported about 45...with that data a prop slip calculator can be utilized to tell you if maybe your tach is incorrect, or you are mis-reporting your pitch, or if your outdrive has a non-stock gear ratio. This is all critical info to know for prop selection. If I assume 1.62, typical for a 5.0, you should be running somewhere around 50 to 57 mph at 5,000 rpm at normal slip. Your reported 45 gives us 26% slip...which is an awful high number, and enough to make me suspect some of your data. Is it possible your tach is inaccurate?, or is my assumption of 1.62 ratio wrong? If your data points are indeed accurate, then I revert to recommending a 23 pitch prop, depending on what exactly you have now, and what your goals are....
For everyone's info, the operating range of this engine is most likely 4,200 to 4,600....can the owner confirm? So far we don't even know the make make/model of the motor in question...I am assuming Volvo, OMC, or Mercruiser sterndrive. All of those should be in that operating range for that vintage.
