Hi everyone. I've searched through the threads and found some information about mounting second batteries, but didn't find any where the second battery on an 18' SuperSport was back in the stern area. I was hoping to put a second battery back in the stern but with my VRO oil reservoir I don't think I have room under the splashwell for a second battery.
I've read that others have mounted a second battery up in the bow area. Right now my '87 has just one battery, and given it has an electric bow mount trolling motor I would really like to set it up with a second battery.
I see a few options:
1) Re-wire the trolling motor to use a dedicated deep cycle battery that I put up in the bow under the front seat. I'd then pull it out after each use and charge it. Everything else would run off the primary battery.
2) Figure out where I can get the second battery mounted back in the stern and set up a switch (off, 1, 2, both). This would be ideal I think.
3) Some alternate second battery location on a switch.
I'd like to hear where you have your second battery located. Thanks
