goodyear seabee
wcqgypsy
goodyear sea-bee 3 model 2253619 serial 717685 does anyone know the year of this motor and weather or not it is air cooled. Thanks Ray
tmcalavy
Re: goodyear seabee
My book stops at 1957...which used the 36XX series, stopping at the 25 hp 3617. Guessing yours is 58 or later. It is water cooled.
F_R
Re: goodyear seabee
It is a 1958, Made by Gale Products Division of OMC. It is a Gale model 3D15. Water cooled. Fuel mix originally was 16-1, but was changed to 24:1. Nice little motors. I have it's Gale cousin.
wcqgypsy
Re: goodyear seabee
I am having trouble with overheating. Where is the water pump? Is it the rubber ring behind the propeller housing? How do you tell if it is worn out? It has no vanes. Thanks Ray
F_R
Re: goodyear seabee
The impeller, properly called a "rotor" is behind the propeller. Grease leaking out of the gearcase makes the rubber swell up and then it won't work. The rotor should be a close fit on the eccentric in the center and the outer diameter should just touch the housing at some point. Except for where it is touching, there should be a space. As the shaft and eccentric rotates, the space progresses from the intake side to the outlet side, then disappears. As it dispappears, water that was trapped in the space is forced up through the water tube. Then it starts the cycle all over again.
Early models had holes in the propeller to force feed the pump. Ours has the propeller a tad larger than the gearcase, forming a scoop to force water into the pump from forward motion of the motor through the water.
