Re: Got a new boat and dont like my HIGH 5 prop need advice
Ok i just took the boat out, and at i am at 4500 rpm. With my high 5 19p prop. at exactly 50mph.
The top of the motor states Max rpm at WOT is 4200-4600 its a non vortec 5.7
I know i am beating a dead horse here. but what would a 21p 3 blade prop do? drop me down to 4k? at WOT. and give me a few more mph?
I have a set of vortec heads in the garage, could i swap those out and get a 4bbl carb and intake and hit 60+ mph? maybe more? i am guessing that swap would give me 60+ hp
I am going to swap my high 5 17p on today and see how she does out of the hole.
What kind of load was that 4500rpm with? If lightly loaded, then the 17P high 5 will be a better match when you load back up with 6 folks. IMHO, no reason to go buying more props, at least for the wakeboarding part. If you could go demo a few props you might find something better, but the 17P high 5 seems like it should be a pretty good match for the application.
That being said, as the other guys have mentioned, getting a good pull for wakeboarding with a full boat is a very different application than shooting for 60mph lightly loaded(which BTW, if you look at 21+ bowriders on boattest.com, you will see none of the approach that mark. Even the faster ones are mid 50s). I completely understand the desire for speed. When I got my new little Glastron, I was hoping for 55. Managed 53.4 all by my lonesome, but when we actually had people in the boat and I tried to slalom, the desire for speed was replaced by the desire to not be dragged behind the boat for 15 seconds before getting out of the water. Dropped some pitch and went to a 4 blade and now it pulls much better. I'll never be north of 50mph again, but I've come to accept that.
That being said, and this is pure conjecture, but I personally would guess a 21" 3 blade would actually not drop your rpm too much if at all coming from the high five. You very well might be able to spin it well enough to see mid 50s. But it would very counterproductive to you're wakeboarding desires, and as other have said, only really useful for bragging rights...or possibly outrunning an approaching thunderstorm.
Also, couple of other things I wanted to mention. You might want to check out some wakeboarding tutorial vids. Either buy one or look online. If you're friends aren't able to hang on, either they're doing something wrong in the water or the driver is being too heavy on the throttle. Both of which should be addressed in a good instructional vid...
Lastly, if you really hate that 19P high 5 and want to throw it out, I can give you my shipping address and you can throw it my way.
I could even give you a 23P Aluminum prop in return...HA!
