got a new to me motor, could a quick rundown,,,,
poor man
i just bought a 17.5 hydrosports VL 270 with a 150 mercury black max on it. it starts and seems to run great but i need to know what the gas/oil ratio is and maybe the year? would be nice, and ANY tips for a new owner (to a mercury motor) thanks
ser number is ser 6607749
carholme
Re: got a new to me motor, could a quick rundown,,,,
Comes up as:
150 V-150 V6 6443213 6616990 1984 USA
From here:
Mercury 2-takt, V6, 6-cyl, 135 - 175 hp, produktions?r, modellguide
Parts List:
150 H.P. XR-2 MARATHON MAGNUM (V-6) (1978-1985 COMBINED BOOK) - Mercury, Mercruiser, Force, etc. Parts Lookup
Service Manual P/N: 90-976583
Until you get an OEM manual, here is a link to the condensed version of the CLYMER manual which will help you get started. Download it soonest to your computer as the link is short lived.
Small Engine Repair Reference Center Home: MERCURY - MERCURY V-6 (EXCEPT 300 AND 3.4L).
Does your boat have an oil system as seen under OIL INJECTION COMPONENTS in the parts List?
Gerry
poor man
Comes up as:
Gerry
not that i seen, im going to look closer at the motor now, the guy said "somebody" told him to use a pint of outboard oil with 6 gallon of gas,,,,, thats why i asked here because i know i can get the "right" answers :)
should an 84 model have oil injection ?? thanks
carholme
As you see in the parts list they did but someone has removed it as many do and pre mixes the fuel oil. The ratio is 50:1
Gerry
Dukedog
As for year, if you can identify tha parts I describe you will find a "build" date stamped in tha block. At tha base of no. 2 cylinder on tha BLOCK half where it splits with tha FRONT (crankcase) half there is a date stamp. It will be 1/8" numbers like this example, 09/30/84. It should be just behind tha advance timing arm. Might be covered with paint but its there. All V6's from '76 up have it..................
poor man
yep i understand il look when i get back home..... thanks
