I need to pull the bearing housing assembly from the lower unit prop shaft, etc. Things don't look too corroded with salt in there, but I think it's been a long time (or never) that it's been pulled (engine's new to me).
1) Will a harmonic balancer puller with longer bolts to reach the 2 tapped holes work, or do I need the factory # 90095 puller?
2) Will it be necessary to heat things up?
3) Any hints, tips or advisories much appreciated.
