got it running again!
tschamp20
success! after replacing my stator w/. one i got from chinewalker over on ebay.but i have a question, i tested my rectifier according to joe reeves proceedure and it failed, meaning an ohm reading both ways. but my tach works fine and the voltage increases ,albeit slightly, as i throttle up. is it bad.
when the motor suddenly died at cruising speed prompting this fix i noticed a slight bit of steam come from the 2 holes in the exhaust housing.then tonite when i first started it it steamed a bit then stopped. is this anything to worry about?
115esl73m
tschamp20
Re: got it running again!
IS THE STEAM NORMAL?????wow thanks for the help
