Ok got the used motor today and this is what I found. Needs a new starter pinion as I mentioned earlier. It seems to be in decent shape, but I have a couple questions. Take in mind I have a repair manual on the way because I plan on doing all the repairs that I am capable of doing.
1. Lower unit oil drained and looked like a light chocolate milk color. I am pretty sure this indicates water is getting in somewhere? The lower unit isnt cracked anywhere and shows no damage, so would I need to just get a lower unit seal kit?
2. can you power wash an inboard? its kinda greasy dirty looking and I would prefer it to be clean looking. If anyone knows a safe way to clean the engine, I would appreciate it.
so here is what I am going to do initially and you guys let me know if there is anything else you would recommend.
change the old worn out starter pinion gear, replace lower unit seals, and change out the impeller.
thanks
thanks
