Hi everyone. I am a newbie so please be gentle
My wife and i bought a lake house (more like a cabin
) at Lay Lake in Alabama. The seller asked if we wanted to buy his pontoon boat for $4k. It is a Suncruiser Trinidad 240 with a 115 Evinrude. We said ok. Today the rookie took it out for a test drive with my wife and the real estate guy. The boat apparently hasnt been used this year as there were spiderwebs on the motor and other parts of the boat. It needs to be cleaned up good but the carpet looked good and the seats were clean but had been taped in a couple of places where the seams apparently are coming loose.
Anyway after taking out the totally dead cranking battery the motor cranked up right away. It sounded smooth and quiet. We went out and after a couple of minutes opened it up. It topped out at 27mph and 6k rpm. After a few minutes we noticed wet spots on the carpet about in the middle of the boat so there is a leak obviously.
My questions are:
1. Does 27mph and 6krpm seem right for this size boat with 3 adults on it?
2. The real estate guy said the water was coming up from under the boat and leaking between the plywood sheets making up the deck. He said it should just need to be caulked. Does this sound right?
I intend to have a good trolling motor installed and will put it on the trailer to take it to the installer. While doing this i am going to ask him to check the plywood and make sure it is ok and if so caulk the joints.
I am thinking i should just have him kind of do a thorough check of everything while he has it since i dont plan to take it out of the water till winter.
As i said i am a total rookie so i was hoping to get suggestions as to whether this sounds like the right way to go from the start.
Thanks in advance and i can tell i am going to love this forum
My questions are:
