I have a video to make things easier, We finally got the 4.3 back in and running with timing adjusted, and it seems to be running well, my biggest concern is the noise the outboard makes when you engage forward or reverse, its almost like a grinding clanking noise, I don't know if this is normal.
In the video I took we revved the motor a few times after it had warmed up just to show it stops once you throttle up and it only does it for a tiny length of travel on the throttle control, we already took the linkage off and adjusted it as per the manual's instructions.
Is this a normal sound we noticed it is a longer grinding noise if you engage forward or reverse slower and a louder quick clank if you are quick with it.
This is a Alpha One Gen 2 from a 2004 boat.
The other thing I am noticing is that the engine is bouncing off a rev limiter at around 3500 rpm yet the throttle still has a bit of travel forward, I only let it hit the rev limiter once as it caught me by surprised but do these engines have a low rpm limit without load or anything? 3500 seems low according to the engine specs 4800rpm should be WOT rpm, and the fact that I adjusted the throttle linkage twice to spec and I still have so much travel in the throttle control seems a bit odd.
